liambeguin
running Vivado from Git Bash on windows
I've written a Makefile to generate Vivado projects which was mostly developed on Linux.
We chose to use Make because on windows, it comes with the Vivado installer.
Our windows our procedure is:
  1. open Git Bash in the project directory
  2. source /c/Xilinx/Vivado/2018.2/settings64.sh
  3. run "make project" which basically calls vivado with a tcl script to generate a project.
My problem is that the shell scripts called when running /c/Xilinx/Vivado/2018.2/bin/vivado seem to not be compatible with the version of uname shipped with the Vivado installer:
$ which uname
/usr/bin/uname
$ uname MINGW64_NT-10.0
$ source /c/Xilinx/Vivado/2018.2/settings64.sh
$ which uname
C:\Xilinx\SDK\2018.2\gnuwin\bin\uname.EXE
$ uname
windows32
/c/Xilinx/Vivado/2018.2/bin/loader doesn't check for `uname` == `windows*`.
I'm wondering if my procedure is wrong or if this is a known issue.
Liam
Tags (3)
liambeguin
I fixed this but skipping setting64.sh completely.
$ cat ./win-setup.sh
#!/bin/sh
VERSION=2018.2
export PATH="${PATH}:/c/Xilinx/Vivado/${VERSION}/bin"
export PATH="${PATH}:/c/Xilinx/SDK/${VERSION}/gnuwin/bin"
$ source ./win-setup.sh
$ vivado -help
vivado
Description:
Vivado v2018.2 (64-bit)
liambeguin
#!/bin/sh
VERSION=2018.2
$ vivado -help
vivado
Description:
