syntax error location/cause
does vivado explain the cause of syntax error and its location?  right now it only tell me there is syntax error but i couldn't find feature that the cause or location(line #) etc
i'm looking for cause in simulation testbench
Re: syntax error location/cause
Hi @s002wjh
Check tcl console for error message and line.
Vinay
Which version of Vivado are you using?
Navigate to message window to see the details.
Thanks,Vijay
