synthesis error
When I run synthesis, the following error message appear. Last year, same project was working.
error code 80070002
Hi @mafzal,
Is the date/time/timezone correct on your computer?
This can sometimes cause these errors.
Please let me know if it doesn't work so we can solve this for you!
Sincerely,
Courtney
Please don’t forget to reply, give kudos, and accept as a solution if you found this helpful!
HI @mafzal
Which Vivado version are you using with which OS version? Make sure you are using a supported OS for respective Vivado version. Check UG 973 for this info.
hemangd
