system integration
hi edv,
I'm using ISE 9.1 with updated webpack. I'm Integrating my code in which there are about 20-25 child modules.
Each time I add one module and test either it's properly responding or not. Later I'm adding another and repeating the same.
So I know my lower module's net list will not change at all. However some extra control signal will be tapped and connected.
Therefore I feel I'm wasting time in re-generating net list again and again.
Is there any way out by which I can just update the netlist for currenly added module and rest will remain as it was?
If yes how do I take advantage of it?
Pl. help.
Kishor
Re: system integration
Kishor,
Yes, use Partitions --> http://www.xilinx.com/itp/xilinx10/isehelp/ds_c_overview.htm
In summary, for each child submodule, you can preserve the synthesis netslist, placing and/or routing.  So if the child module has been left untouch, the tools does not re-synthesize or re-implement that child.
Use the link above, as well as the "See Also" links in that page, for further information on how to use partitions.
Hope this helps.
Eddie
