helj@
unable to program the PROM
There is no error during synthesis, implementation and bitstream, and my board(Artix-7 nexys 4 ddr) can be programmed, which means FPGA configuration file can be downloaded into the board via JTAG.
However, I can not program the PROM. The .bin file can be generated, but I can not select "add configuration memory device".
I tried to disconnect the board or relaunch the project, but they did not work.
What's wrong??
thakurr
Hi helj@
Please follow the steps mention in UG908, chapter 5:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug908-vivado-programming-debugging.pdf
Rohit
Rohit
pratham
helj@ Could you please provide the complete screenshot of the Vivado?
Right-click on the device and try to add the configuration memory part from there.
-Pratham
helj@
Sorry, it doesn't work..
pratham
helj@ Did you use the tcl command to program the flash?
Also, you have not provided the screenshot.
-Pratham
helj@
Sorry I just run into another problem: https://forums.xilinx.com/t5/Design-Entry/synthesis-failed-without-any-error-message/td-p/759819
I can not run synthesis on my computer...So I can not get screenshot...
