obal3588
using normal IO pin as ADC data cloak input
I am working to interface ADS5402 to Zynq 7000 Microzed. I mistakenly carrier board for the Microzed ,and I used a normal IO pin as data clock.
Is there another way to contact the normal pin MRCC/SRCC ?
yangc
Hi @obal3588
Did you connect ADC data clock with normal IO (not MRCC or SRCC) in physical? If so , you have to use normal IO as clock input. It will influence the performance of the clock and have to set the tcl command "set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets{*}]" to pass the DRC check.
