Scholar beandigital
vdma read part of an image
i have an image stored in DDR3 that is 256 x 256 in RGB 8-bit format. I want to read 64x64 blocks from the image starting at the top and working along until I get to the bottom (16 blocks in total). Is it possible to do this with the vdma IP? If so what settings would I need to use in the registers?
Re: vdma read part of an image
You can do it in one of a couple ways that I can think of:
1) Configure the VDMA for 16 frames and set the start addresses to intermediate block location in the original frame.
2) Update the VDMA start address every block
www.xilinx.com
www.xilinx.com
Scholar beandigital
Thanks for the help. Can I just clarify the parameters I would use.
The horiz size would be 64 x 3 bytes.
The stride would be 256 x 3 bytes.
The vert size would be 64 lines.
The address would be the start address of the block in the image.
Oh yeah, good catch on the stride. That looks right to me, I think.
www.xilinx.com
