08-03-2017 11:18 AM
is there way to tell vivado not to give error for unused pins? or tell it to ignore it.
08-03-2017 04:42 PM
Hey @s002wjhw,
I don't remember Vivado ever complaining about unused pins.
Maybe give an example for the Warning or Error you are seeing?
Best,
Herbert
08-04-2017 08:38 PM
I believe Vivado do not to give error for unused pins. Please refer below answer records for more details
https://www.xilinx.com/support/answers/62560.html
https://www.xilinx.com/support/answers/68114.html
08-07-2017 11:25 AM
well I receive these errors, and looking at XDC constraint, these pins is not assigned anywhere.
08-07-2017 11:28 AM
08-07-2017 11:52 AM
The image shows 32 unplaced terminals.
Vivado is trying to place the listed output ports (AMX_*, FMC*) on pins which conform to the specified LVCMOS18 I/O standard and group, but at this point, there are none left.
Hope this helps,
Herbert
08-07-2017 01:43 PM
08-07-2017 01:49 PM
@s002wjhw ... the only thing I did was upgrade the ip ...
Well, the IP is a huge part with many, many files, some of them will affect the synthesis (mostly the HDL), some of them will contain constraints and that is where I would start to look.
I.e. compare the IP related constraints before the upgrade with the ones from after the upgrade.
Hope this helps,
Herbert
