vivado 2017.4 device utilization report
I feel this should be easy to do as have done for other FPGA vendors so sorry if it is and I being dumb.
I have done the synthesis of my Artix-7 design and now I want to click something in Vivado 2017.4 and see a post synthesis report showing the utilization of all the different elements in the device. Perhaps a neat little table showing the number of IO available versus what I have used, slices available vs used, distributed RAM available vs used, DSP slices, logic cells and so on.
Sorry if I am being blind and it is obvious
thanks in advance for any help
Scholar jmcclusk
Re: vivado 2017.4 device utilization report
First you need to "Open Synthesized Design"  (or "Open Implemented Design").    Then go to the Project Summary window, and there should be a panel or section with the device resources used..  You can select either table or bar chart mode.
Scholar jmcclusk
found it! thanks for that ..
