danmari
vivado.bat not works
E:\programs\Xilinx\Vivado\2020.1\bin>vivado.bat
****** Vivado v2020.1.1_AR75516 (64-bit)
**** SW Build 2902540 on Wed May 27 19:54:49 MDT 2020
**** IP Build 2956692 on Thu Aug 6 01:41:30 MDT 2020
** Copyright 1986-2020 Xilinx, Inc. All Rights Reserved.
I have run vivado.bat, but it just shows the following error and does not start.
I have confirmed that librdi_coretasks.dll and HARC.cfg exist in the win64.o directory.
Thanks for your help.
ERROR: [DRC 23-83] Unknown rule deck name 'civ_checks' from HARC.cfg
Could not load library 'librdi_coretasks' needed by 'core', please check installation.
while executing
"error "$result\nCould not load library '$library' needed by '$feature', please check installation.""
(procedure "rdi::load_library" line 4)
invoked from within
"rdi::load_library core librdi_coretasks"
(file "E:/programs/Xilinx/Vivado/2020.1\lib\scripts\rdi\features\core\core.tcl" line 6)
ERROR: [Common 17-217] Failed to load feature 'core'.
INFO: [Common 17-206] Exiting Vivado at Fri Apr 2 19:46:48 2021...
