Visitor rnp
vivado editor vhdl cursor at the end of line issue
Hello everybody,
I am using the vivado to edit/enter VHDL code and I am having the following issue:
1 - open vhdl file
2 - edit entity port
3 - go to the end of line
4 - cursor stays 2 characters before the end of the line
This is quite incovenient behaviour, makes it difficult to edit/enter new VHDL code. Any suggestions? Thanks in advance.
Additional Information:
- Vivado 2018.3 / 2019.1
- Arch Linux /  5.2.1-arch1-1-ARCH
Visitor rnp
Re: vivado editor vhdl cursor at the end of line issue
Hello @hemangd ,
Sorry for the late reply and Thanks for pointing out the UG973. I installed Ubuntu 18.04.3 LTS (64-bit) + Vivado 2019.1  Update 2, and the error did not occur.
Nevertheless, I found a work around  for the cursos positioning error, it may be helpful for someone else using a Linux distribution that is not supported:
1 - In the flow navigator, click on Settings, direcltly under PROJECT MANAGER)
2-  Under Tool Settings,  click on Text editor, and in the sub-option VDHL
3- Unter Text Styles listbox, click on IEEE
4- On the right side uncheck the bold checkbox (see attached image file)
5- Click on OK to apply the change and close the Settings window
rnp
Scholar dpaul24
@rnp,
Do not use the Vivado supplied editor. It is crap and there are remote chances of it being improved.
Most of us here here don't use the built-in editor. If you are on Windows platform, suggestion is to switch to Notepad++. If you are on Linux, use your favourite editor (Nedit, emacs, etc).
Vivado can be configured from its Tools --> Settings to use the editor of your choice.
FPGA enthusiast!
All PMs will be ignored
Visitor rnp
I agree, the editor has a lot of problems, but I could not imagine that a problem with such a simple functionality could happen.
It is also quite unfortunate that Xilinx does not put an effort to fix such simple (but annoying) bugs .
Cheers.
Scholar dpaul24
@rnp,
It is because the in-built text editor is a non-revenue generating entity for Xilinx. :-)
FPGA enthusiast!
Scholar drjohnsmith
Dont hold your breath
Its evident that Xilinx do not use VHDL internally, so its very unlikely to get fixed.
Suggestion is to install the notepad++ external editor, that can be substituted in vivado directly ,
https://www.xilinx.com/support/answers/57719.html
https://notepad-plus-plus.org/download/v7.7.1.html
Feel free to Kudos if ths was helpfull
Hi @rnp,
The issue is not reproducible at my end.
I will suggest use supported OS for Vivado 2019.1 and then check.
From UG 973:
Supported Operating Systems
Xilinx® supports the following operating systems on x86 and x86-64 processor architectures.
• Microsoft Windows 7 SP1 Professional (64-bit), English/Japanese
• Microsoft Windows 10.0 1809 Update; 10.0 1903 Pre-release (64-bit), English/Japanese
• Red Hat Enterprise Workstation/Server 7.4, 7.5, and 7.6 (64-bit)
• SUSE Linux Enterprise 12.4 (64-bit)
• CentOS 7.4, 7.5, and 7.6 (64-bit)
• Ubuntu Linux 16.04.5, 18.04.1 LTS (64-bit)
hemangd
Visitor rnp
Hello @hemangd ,
rnp
