Observer benzao
vivado internal exception----when i use zynq7 processing system(5.3) re-customize ip.
hi,
when i use re-customize ip to config zynq 7010, it occur "a total of xxx internal exception have been detected, vivado may be in an unstalbe state, would you like to exit now?
there is detials information:
# Vivado v2013.4 (64-bit)
# SW Build 353583 on Mon Dec 9 17:49:19 MST 2013
# Current time: 2/5/14 3:53:50 PM
# Process ID: 2724
# Platform: Windows
# This report is an indication that an internal application error occurred.
# This information is useful for debugging. Please open a case with Xilinx
# Technical Support with this file and a testcase attached.
java.lang.NullPointerException
at ui.data.coregen.a.a.e.c.bw.<init>(SourceFile:28)
at ui.data.coregen.a.a.e.c.bF.bIR(SourceFile:145)
at ui.data.coregen.a.a.e.c.bF.bGN(SourceFile:104)
at ui.data.coregen.a.a.e.c.ce.bGO(SourceFile:105)
at ui.data.coregen.a.a.e.c.bF.<init>(SourceFile:33)
at ui.data.coregen.a.a.e.c.bB.<init>(SourceFile:65)
at ui.data.coregen.a.a.e.c.bz.setVisible(SourceFile:46)
at java.awt.CardLayout.show(CardLayout.java:546)
at ui.data.coregen.a.a.e.c.bX.actionPerformed(SourceFile:433)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:290)
at java.awt.Component.processMouseEvent(Component.java:6505)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3320)
at java.awt.Component.processEvent(Component.java:6270)
at java.awt.Container.processEvent(Container.java:2229)
at java.awt.Component.dispatchEventImpl(Component.java:4861)
at java.awt.Container.dispatchEventImpl(Container.java:2287)
at java.awt.Component.dispatchEvent(Component.java:4687)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422)
at java.awt.Container.dispatchEventImpl(Container.java:2273)
at java.awt.Window.dispatchEventImpl(Window.java:2719)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:735)
at java.awt.EventQueue.access$200(EventQueue.java:103)
at java.awt.EventQueue$3.run(EventQueue.java:694)
at java.awt.EventQueue$3.run(EventQueue.java:692)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87)
at java.awt.EventQueue$4.run(EventQueue.java:708)
at java.awt.EventQueue$4.run(EventQueue.java:706)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:705)
at ui.frmwork.a.e.dispatchEvent(SourceFile:72)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
Scholar pratham
Re: vivado internal exception----when i use zynq7 processing system(5.3) re-customize ip.
I am facing problem with the patch attachment. Can you please post your email id here. i will send the patch and usage details
-Pratham
What OS is this?
Can you attach a test case?
Deepika.
Deepika.
Scholar pratham
Are you setting NAND flash bit?
-Pratham
Observer benzao
my os is windows 7
the attachments is my project files,
regards
ben
Observer benzao
yes, i use nand flash,
regards
ben
Scholar pratham
I didnt faced any error when i customized the IP.
I do not see nand flash bit as enabled. i am facing some issues while attaching the patch.
Please send me your email id. i will send you the patch.
-Pratham
Observer benzao
hi, pratham,
thank you,
where is the 2013.4_patch.zip? i could not find it.
regards
ben
Observer benzao
hi,
the attachment is my project, it use nand flash bit, and can not config zynq 7010.
regards
ben
Scholar pratham
-Pratham
Newbie vraj
I am getting the exact same error when trying to recustomize the Zynq PS IP after upgrading the project from 2013.2 to 2013.4 and upgrading the IP from 5.2 to 5.3.  This problem only occurs with recustomizing the IP in the upgraded projected - not when starting from scratch.
This thread is marked as answered, but I'm not seeing anything that would solve this for me.
Scholar pratham
Was the NAND flash bit set in 2013.2 ?
-Pratham
