vivado synthesis not running
while trying to run synthesis in vivado. the synthesis does not complete gets hung in "running multiple block runs".
thanks in advance,
Hello @divya2m
I think a little bit more information about your project is required to see what is happening.
Do you see any errors come up during synthesis? Screenshots of any errors would be very useful.
What version of Vivado are you currently using?
Is this a large design you are creating? A large design with many IP blocks will have an increased runtime, so it may just be taking some time.
I have attached a link to a past forum that you may find useful. I have also attached some answer records that could help in debugging.
Forum: https://forums.xilinx.com/t5/General-Technical-Discussion/multiple-block-designs/td-p/553350
AR1 (Special characters in filepath): https://www.xilinx.com/support/answers/61082.html
AR2(Run hangs on queued status): https://www.xilinx.com/support/answers/60140.html
I hope this helps!
