Visitor seanlittle
vivado tcl exec preserve environment
It seems to me that running external shell commands from Vivado is a little...quirky.
I need to preserve the PYTHONPATH variable that exists in the parent shell, but nothing I do seems to preserve that variable, or even allow me to redefine that variable when running a command using EXEC. Here is an example of what I'm trying to do:
puts $env(PYTHONPATH)
/cygdrive/c/work/prj/pylib
exec bash -c "echo \$PYTHONPATH"
<no output>
exec bash -c "PYTHONPATH=$env(PYTHONPATH); bash -c 'echo \$PYTHONPATH'"
<no output>
exec bash -c "echo $env(PYTHONPATH)"
exec bash -c "export PYTHONPATH=test && echo \$PYTHONPATH"
<no output>
exec bash -c "PYTHONPATH=test; bash -c 'echo \$PYTHONPATH'"
<no output>
What is going on here? I have tried *lots* of other permutations of these commands with the same results. I'd really appreciate any pointers.
Scholar markcurry
Re: vivado tcl exec preserve environment
I can't offer much suggestions, other than pointing out the root cause of your problem likely is NOT vivado.
You're using Vivado, under cygwin running on a windows machine  Most of the quirks you've listed are because of those latter two items not Vivado.
(Must... Resist... Windows bashing....)
I think your troubles are related to how a Windows Python exe is interacting with Cygwin, and where it sends STDERR/STDOUT.
Try a cygwin version of python perhaps?
Mark
Visitor seanlittle
Thanks for the reply. Yes I would much rather be using Linux. That isn't an option for me right now, unfortuneately.
I am using the cygwin, and I am using the python installed by cygwin.
But that is different from the problem that I am seeing. I can't seem define a variable in bash that can then be immediately used. It doesn't matter what python executable I am using if I can't do that... Maybe I should try using "cmd" instead of "bash" and attempt a non-cygwin version of python?
Scholar markcurry
This is NOT the cygwin version of python.  The cygwin version of python will show up as being under  /cygdrive/c/cygwin/...
Mark
Visitor seanlittle
That is the value of the PYTHONPATH environmental variable I am attempting to preserve. This is the version of python I am using:
exec bash -c "which python3"
/usr/bin/python3
Thanks again.
Visitor seanlittle
As Mark implied, it seems the best way to get around this is to not use Vivado through cygwin. I was able to fix my python code so that it didn't need the PYTHONPATH env variable. But then the real problems started. Running python from Vivado TCL on cygwin breaks all the file paths. It is completely crazy. Neither the windows "c:/..." path syntax or the cygwin "/cygdrive/c/..." path syntax works. Python just fails to open files or directories complaining that the target doesn't exist. When they do. Seriously.
I was able to get things working by just not using cygwin. I'm posting here in to save some one else some time. Don't do this.
To some Xilinx guy who might care...Are there any plans to support cygwin? I have been quite successful using Altera/Intel Quartus through cygwin. Thanks.
