vivado to ISE
Hello all,
I have a project in Vivado, I want to know how can I open it using ISE?
Migaration from ISE to Vivado is possible but the other way around is not possible.
Satish
Satish
Tools are forward compatible not backward compatible.
ISE does not support ,xdc & vivado file format.
So you won't be able to source Vivado project in ISE. Since your project is in vivado so for 7 series we recommend Vivado.
