behzad34
vivado to ISE
Hello all,
I have a project in Vivado, I want to know how can I open it using ISE?
yenigal
Migaration from ISE to Vivado is possible but the other way around is not possible.
Satish
yenigal
Satish
hj
Tools are forward compatible not backward compatible.
ISE does not support ,xdc & vivado file format.
So you won't be able to source Vivado project in ISE. Since your project is in vivado so for 7 series we recommend Vivado.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
