Visitor avic
what's the reason of using fifo block ram instead of built-in fifo?
Scholar austin
Re: what's the reason of using fifo block ram instead of built-in fifo?
a,
fifo block ram is the built-in fifo.
Austin Lesea
Principal Engineer
Xilinx San Jose
Can you give more details on which core or application you are referring where FIFO is built using block ram's instead of the built in FIFO and want's a reason for that.
Satish
If you are using FIFO generator IP core, refer to page-15 of http://www.xilinx.com/support/documentation/ip_documentation/fifo_generator/v12_0/pg057-fifo-generator.pdf
Deepika.
Deepika.
