Scholar ronnywebers
where to find Xilinx interface naming conventions
When I create for example an external port on an AXI IIC interface, IPI creates a 'bundled' port named 'IIC' by default.
In the XDC file, package pins can be connected to these IIC interface signals.
However these signal names in the XDC file seem to adhere to strict naming conventions, for example for the IIC I found somewhere in a tutorial that these must be named like :
set_property PACKAGE_PIN Y26 [get_ports IIC_scl_io]
set_property PACKAGE_PIN Y25 [get_ports IIC_sda_io]
so the full port name must be 'the name of the interface port' (IIC here) followed by _scl_io and _sda_io
  • Q1 : Where can I find the documenation / conventions for naming these 'xilinx interface' pins, for all pre-defined Xilinx interfaces? Or must I use IO planner to find these out?
  • Q2: Also where can I find information on how to define / re-use my own interface definitions? Is there any doc / tutorial on this?
Teacher muzaffer
Re: where to find Xilinx interface naming conventions
1) checkout ...Xilinx/Vivado/20..../data/ip/interfaces
2) Try the menu item "Create Interface Definition" in Vivado.
Teacher muzaffer
Q2: The underlying standard is IEEE 1685-2009 IP-XACT available at no cost - thx to Accelera - on the IEEE standard https://standards.ieee.org/findstds/standard/1685-2009.html . You'll find some examples of interfaces in the Xilinx install directory. For the rest you're pretty much on your own...
I'll advise you - once you understand IP-XACT - to make a small design, compile it and have a look to the files generated by Vivado. We went through this process and once yo uunderstand it it works pretty well and is quite powerful. Xilinx provides an IP packager but we find it better to write the xml files on our own and only use the IP packager to verify the syntax... because the only real drawback w/ Vivado and IP-XACT is that there is not (yet) a really good IP-XACT debugging capabilities.
