why am I getting these warning
   I am getting the
WARNING: [Synth 8-3331] design system_stub has unconnected port FCLK_RESET1_N
WARNING: [Synth 8-3331] design system_stub has unconnected port FCLK_CLK1
but looking at the code it is driven from the system as shown below;
entity system_stub is
port (
    FCLK_RESET1_N : out std_logic;
    FCLK_CLK1 : out std_logic;
end system_stub;
architecture STRUCTURE of system_stub is
component system is
port (
end component;
begin
system_i : system
port map (
FCLK_CLK1 => PCLK100MHZ,
FCLK_RESET1_N => PROC_SYSRSTL,
Can anyone to please let me know why am I getting the warning?
Best Regards,
Fred
Re: why am I getting these warning
Refer below discussion:
http://forums.xilinx.com/t5/New-Users-Forum/VHDL-Beginner-Not-able-to-solve-port-mapping-error-Cannot-read/m-p/440334/highlight/true#M9356
Anusheel
Helpful answer -> Give Kudos
Can you show us complete instantiation of system module?
In the system_i instantiation in the rhs part you need to have these port names FCLK_CLK1 etc.
Deepika.
Deepika.
There is no connection for below ports:
port (
Anusheel
Hi Deepika,
  where is this rhs located? do you want the system.bd file?
Regards, Fred
Just attach the top level wrapper file where you have instantiation of system_i module.
If this is block design wrapper file just remove this file and create the wrapper file again. See if this helps.
Deepika.
Deepika.
Hi Deepika,
  Here is the wrapper...
Regards, Fred
It looks like you have edited the wrapper file. I see that you have not connected the FCLK_RESET1_N and FCLK_CLK1 ports in the design. You have defined them as output ports for system_stub module but no where assigned them.
If you want to connect these ports to submodule output pins then you need to write them in right hand side of the instantiation as below
submodule_output_port1 => FCLK_RESET1_N,
submodule_output_port2 => FCLK_CLK1,
Deepika.
Deepika.
  I am doing what you suggested (as shown in the code) but still getting the warning...
Regards, Fred
Hi Fred,
Can you attach the modified wrapper file?
Deepika.
Deepika.
i did but here it goes again...
Fred
Read my earlier post again. I said that you need to have FCLK_RESET1_N on the right hand side where as you have some other signal on line 573.
Deepika.
Deepika.
Hi Deepika,
  I did what you suggested now the tool complain that
[Synth 8-1779] cannot read from 'out' object fclk_reset1_n ; use 'buffer' or 'inout' ...
[Synth 8-1779] cannot read from 'out' object fclk_clk1 ; use 'buffer' or 'inout' ...
I don't want to mark as buffer or inout LOL
Regards, Fred
Anusheel
