wrapper doesn't update when changing a block diagram
I create a block diagram, then an HDL wrapper, synthesize, simulate, everything is fine...
But, when I change the BD to have different i/o the changes don't appear in the wrapper..
What I'm missing?
I tried reset_project (tcl command), resetting and regenerating output products... no luck...
Re: wrapper doesn't update when changing a block diagram
Hi @satguy,
How did you create the wrapper for the BD ? Did you select "auto-update" option while creating the wrapper ? (have a look at below snippet)
~Chinmay
Yes, I created it that way
Which version of Vivado are you using ? After making the changes did you validate the design ? Can you see any critical warning or errors in the log? If possible please share vivado.log.
~Chinmay
Scholar jmcclusk
you need to regenerate the wrapper.   Just select your block diagram, then right click and select "View Wrapper".  It should generate a new one.
2018.2
Yes, of course
No, otherwise I wouldn't expect Vivado carrying on
@jmcclusk
where is that 'view wrapper' you say?
Scholar jmcclusk
Pardon...   it's actually  "View Instantiation Template"    This is the wrapper for the block diagram.
