06-05-2019 06:06 PM
I generated a Multiply Adder xbip_multadd_0 IP via ip catalog to my current project. Within one of my user modules (eg shuffler_1.vhd rtl code) I then declared the component xbip_multadd_0 + instantiation (mult_add_inst:xbip_multadd_0). My shuffler_1.vhd code had no syntax errors. I then expected to see on the sources window the xbip_multadd_0 to be recognized as a sub module of the shuffler_1. However, this was listed as
mult_add_inst:xil_defaultlib.xbip_multadd_0 with a ? (ie file not found!).
I tried adding to my shuffler_1 the following at the very top :
library xil_defaultlib;
use xil_defaultlib.all;
but still I could not get the xbib_multadd_0 to be recognized as a submodule of my shuffler_1 code. Any suggestions to what I am doing wrong here?
Also, why it has added xil_default library name ? Noticed that this was the default library in the project manager settings window.
On other cases when I instantiated a Dual Port RAM (from the IP catalog) in other top-level .vhd codes, this was always recognized ok without adding the xil_default library name.
Will appreciate a prompt reply to this matter & how to resolve it.
Kevin
06-06-2019 01:25 AM
Hi All,
Silly me ! The name I used in the VHDL was xbib_multadd_0 and not xbip_multadd_0.
Problem is now resolved :-)
