xci file is not support for switch
I have generated two .xci files for same sram which are init different values. But  when I switch the .xci files, the init value is keep the last value of generated. The value is changed when switch the .xci file.
Re: xci file is not support for switch
How did you switch the xci file and how did you check the init value of the RAM?
-vivian
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
I use the tcl file for run vivado by add_files command. Forexample, I have two .xci files for same sram, each for different init value, I will select one by manual annotation other in tcl files. Then I will run the tcl and product .bit files for test. The test result will note me the value if changed successful.
