xpm_memory_sprom [Synth 8-6058] Synth Error: [XPM_MEMORY 16-4] ADDR_WIDTH_B (0) value is outside of legal range
I need to have a rom in my design and so i am using xpm_memory_sprom.
this is obviously a simple single port rom. it has only one port (port a).
at the time of synthesis vivado complains that the ADDR_WIDTH_B is 0 .
i dont understand this at all. the ip does not have any port B.
code is something like this:
xpm_memory_sprom_log2_calc_inst0 : xpm_memory_sprom
generic map (
ADDR_WIDTH_A => 4,
AUTO_SLEEP_TIME => 0,
ECC_MODE => "no_ecc",
MEMORY_INIT_FILE => "none",
MEMORY_INIT_PARAM => "00,00,00,00,80,96,a9,bb,cb,da,e7,f4",
MEMORY_OPTIMIZATION => "true",
MEMORY_PRIMITIVE => "auto",
MEMORY_SIZE => 12,
MESSAGE_CONTROL => 0,
READ_DATA_WIDTH_A => 8,
READ_LATENCY_A => 1,
USE_MEM_INIT => 1,
WAKEUP_TIME => "disable_sleep"
port map (
dbiterra => open,
douta => s_log2_fraction0,
sbiterra => open,
addra => s_lut_index0, -- the value coming to this port should be max 127.
clka => clk,
ena => '1',
injectdbiterra => '0',
injectsbiterra => '0',
regcea => '1',
rsta => rst,
sleep => '0'
Re: xpm_memory_sprom [Synth 8-6058] Synth Error: [XPM_MEMORY 16-4] ADDR_WIDTH_B (0) value is outside of legal range
Hi @mamisadegh3
Just change the parameter MEMORY_SIZE to be a multiple of READ_DATA_WIDTH_A and it will pass synthesis.
For READ_DATA_WIDTH_A = 8 and ADDR_WIDTH_A = 4, MEMORY_SIZE  should be 2^4 * 8 = 128 bits.
12 does not makes sense.
Florent
