Participant pthomas
zedboard example project
Is there a way to get the zedboard example project in Vivado 2015.2?
Before (2014.4 I think) for a new project type I could choose a Base Zynq and then choose the zedboard, but now I just see ZYNQ-7 ZC702 Evaluation Board.
thanks,
Paul
Re: zedboard example project
hi,
example project does not seem to exist. Would that be possible to create a new project --> target Zedboard and continue using it?
--hem
Scholar pratham
@pthomas you are correct.Zedboard example project  has been removed from vivado 2015.1 install.
You can port the example design from 2014.4 by just opening the example design in 2015.1, Let me know if you dont have 2014.4 i can attach project here
-Pratham
You can upgrade the example design of 2014.4.1 to 2015.2.
