AXI_GPIO IP block
I am need to use more than one block of AXI_GPIO.
What is the number of channels in the second added block should be? Are they will be 3 and 4 since the in first block the number of channels are 1 and 2 ?
Kindly, find the attached pictures.
Voyager
Voyager
Re: AXI_GPIO IP block
Think of the two AXI_GPIO blocks as completely unrelated IP.  Note in Vivado, each IP has a unique name and is given a unique adress space.  In your C code, you will need to intialize and configure both of the IPs seperately.  Note that there should be a generated file called "xparameters.h" that is added to your SDK workspace.  That file contains #Defines for all of the IP in your design.  Look in there to find the specific info for each IP.
When you read or write the GPIOs, it's the instance pointer that specifies which IP is being accessed.  From your example, you had a read of (&Gpio,1).  To read from the second GPIO, you might have (&Gpio1,1).
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Scholar dpaul24
@ahmed_alfadhel,
Why don't you create, add the block and see it for yourself?
Just change the instiantiation name to axi_gpio_2 and add the block to your design.
FPGA enthusiast!
All PMs will be ignored
Hi @dpaul24 ,
Thank you for your reply.
I meant what should I put inside my C code, in case of multiple AXI_GPIO blocks.
Kindly, see the attached picture.
Scholar dpaul24
@ahmed_alfadhel,
Put a 2 in the place which you have marked.
I think in the 2nd instiantiation, the channels will be 1 and 2 . If the block inst name is different it won't be a problem.
FPGA enthusiast!
Voyager
Voyager
