Can someone check my code to design a 16 bit 4*1mux using data implementation style. I have included the design source code, constraint file and the test bench file
Design source:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity mux4_1 is
    Port ( i0 : in STD_LOGIC_VECTOR(15 DOWNTO 0);
           i1 : in STD_LOGIC_VECTOR(15 DOWNTO 0);
           i2 : in STD_LOGIC_VECTOR(15 DOWNTO 0);
           i3 : in STD_LOGIC_VECTOR(15 DOWNTO 0);
           s0 : in STD_LOGIC;
           s1 : in STD_LOGIC;
           z : out STD_LOGIC_VECTOR(15 DOWNTO 0));
end mux4_1;
architecture dataflow of mux4_1 is
begin
z<=i0 WHEN  s0<= '0' and s1<='0';
z<=i1 WHEN  s0<= '0' and s1<='1';
z<=i2 WHEN  s0<= '1' and s1<='0';
z<=i3 WHEN  s0<= '1' and s1<='1';
end dataflow;
constraint file:
## Switches
set_property PACKAGE_PIN V17 [get_ports {i0}]
set_property IOSTANDARD LVCMOS33 [get_ports {i0}]
set_property PACKAGE_PIN W16 [get_ports {i1}]
set_property IOSTANDARD LVCMOS33 [get_ports {i1}]
set_property PACKAGE_PIN V15 [get_ports {i2}]
set_property IOSTANDARD LVCMOS33 [get_ports {i2}]
set_property PACKAGE_PIN W14 [get_ports {i3}]
set_property IOSTANDARD LVCMOS33 [get_ports {i3}]
set_property PACKAGE_PIN T2 [get_ports {s0}]
set_property IOSTANDARD LVCMOS33 [get_ports {s0}]
set_property PACKAGE_PIN R2 [get_ports {s1}]
set_property IOSTANDARD LVCMOS33 [get_ports {s1}]
## LEDs
set_property PACKAGE_PIN U16 [get_ports {z}]
set_property IOSTANDARD LVCMOS33 [get_ports {z}]
test bench code:
library IEEE;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity mux4_1_tb is
--  Port ( );
end mux4_1_tb;
architecture dataflow of mux4_1_tb is
COMPONENT mux4_1 is
PORT (i0 : in STD_LOGIC_VECTOR(15 DOWNTO 0);
 i1: in STD_LOGIC_VECTOR(15 DOWNTO 0);
 i2: in STD_LOGIC_VECTOR(15 DOWNTO 0);
 i3: in STD_LOGIC_VECTOR(15 DOWNTO 0);
s0: in STD_LOGIC;
s1: in STD_LOGIC;
END COMPONENT;
signal i0,i1,i2,i3:    STD_LOGIC_VECTOR(15 DOWNTO 0);
signal s0,s1: STD_LOGIC;
signal z:    STD_LOGIC_VECTOR(15 DOWNTO 0);
begin
uut: mux4_1 PORT MAP (
i0,i1,i2,i3,s0,s1,z
i0 <= "0000000000000000";
i1 <= "1000000000000110";
i2 <= "1000000000000110";
i3 <= "1000000000000110";
s0 <= '0';
s1 <= '0';
i0 <= "1000000000000000";
i1 <= "0000000000000110";
i2 <= "0000000000000110";
i3 <= "0000000000000110";
s0 <= '0';
s1 <= '0';
i0 <= "1111111111111111";
s0 <= '0';
s1 <= '0';
i0 <= "1000001100000000";
i1 <= "0000000000000000";
s0 <= '0';
s1 <= '1';
s0 <= '0';
s1 <= '1';
i0 <= "0111111111100000";
i1 <= "1111111111111111";
s0 <= '0';
s1 <= '1';
i2 <= "0000000000000000";
s0 <= '1';
s1 <= '0';
i1 <= "0100000000000110";
i2 <= "1110000000000110";
s0 <= '1';
s1 <= '0';
i0 <= "0011100000001111";
i2 <= "1111111111111111";
s0 <= '1';
s1 <= '0';
s0 <= '1';
s1 <= '1';
i3 <= "1111000000000110";
s0 <= '1';
s1 <= '1';
i0 <= "0000001111111111";
i3 <= "1111111111111111";
s0 <= '1';
s1 <= '1';
end dataflow;
What errors do you get?  Can you simulate?  Can you synthesize?  If you simulate, does this do what you expect?
