Custom IP - difference between Data sheet and Encrypted Data sheet?
- IP: Custom
- Vivado: 2018.2
hello,
I'd like to know, what is the difference in using an IP Data sheet and Encrypted Data sheet in Table A-2 found here.
thank you
Re: Custom IP - difference between Data sheet and Encrypted Data sheet?
Hi @theultimatesource, the encrypted datasheet flow was typically used whenever Xilinx produced an IP, for which the datasheet was kept secret, unless you had the appropriate license.
Typically, I don’t think users ever practically made use of this.
