dansci
Custom IP in the RP
I'm a bit confused how to put custom IP into the Reconfigurable Partion.
Custom IP is created as separate project as a Block Design so I generated VHDL wrapper for it.
Now in my project with Reconfigurable Partitions how can I import the Custom IP to it? Its structure is like:
+ProjectTop:
    + RP1
        - <place_for_custom_ip>
    + RP2
    + RP3
    + ProjectBlockDesignWrapper
         - ProjectBlockDesign
himalayan_fpga
You cannot create reconfigurable partition definition with block design as of now. Maybe xilinx will add this feature in future.
jagannath@logictronix.com
dansci
I'm aware of it. That's why I've created wrappers around everything and the top level is VHDL file. So in the partition I have VHDL wrapper for the design which is created as a separate project and I don't know how to put it under that wrapper in the main project hierarchy.
