08-21-2018 11:33 AM
I was recently trying to make a 4x1 mux using a 2x1 mux and i encountered an error while simulating the test bench.
Here's the code for it and a pic for reference of the error i am facing.
2x1 mux code:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx leaf cells in this code. --library UNISIM; --use UNISIM.VComponents.all; entity MUX2_1 is Port ( I0 : in STD_LOGIC; I1 : in STD_LOGIC; S : in STD_LOGIC; Y : out STD_LOGIC); end MUX2_1; architecture Behavioral of MUX2_1 is SIGNAL SBAR:STD_LOGIC; begin SBAR<=not S; Y<=(S AND I1) OR (SBAR AND I0); end Behavioral;
4x1 code
library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity MUX4_1 is Port ( I : in STD_LOGIC_VECTOR (0 to 3); S : in STD_LOGIC_VECTOR (0 to 1); Y : out STD_LOGIC); end MUX4_1; architecture Behavioral of MUX4_1 is COMPONENT MUX2_1 is Port ( I0 : in STD_LOGIC; I1 : in STD_LOGIC; S : in STD_LOGIC; Y : out STD_LOGIC); END COMPONENT; SIGNAL A,B:STD_LOGIC; begin M1: MUX2_1 PORT MAP(I0=>I(0),I1=>I(1),S=>S(0),Y=>A); M2: MUX2_1 PORT MAP(I0=>I(2),I1=>I(3),S=>S(0),Y=>B); M3: MUX2_1 PORT MAP(I0=>A,I1=>B,S=>S(1),Y=>Y); end Behavioral;
4x1 test bench
library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity MUX4_1_TB is -- Port ( ); end MUX4_1_TB; architecture Behavioral of MUX4_1_TB is COMPONENT MUX4_1 is Port ( I : in STD_LOGIC_VECTOR (0 to 3); S : in STD_LOGIC_VECTOR (0 to 1); Y : out STD_LOGIC); END COMPONENT; SIGNAL I_TB :STD_LOGIC_VECTOR (0 to 3); SIGNAL S_TB :STD_LOGIC_VECTOR (0 to 1); SIGNAL Y_TB : STD_LOGIC; begin M1:MUX4_1 PORT MAP(I_TB(0),I_TB(1),I_TB(2),I_TB(3),S_TB(0),S_TB(1),Y_TB); PROCESS BEGIN I_TB<="0000"; S_TB<="00"; WAIT FOR 5 NS; I_TB<="0001"; S_TB<="01"; WAIT FOR 5 NS; I_TB<="0011"; S_TB<="10"; WAIT FOR 5 NS; I_TB<="1000"; S_TB<="00"; WAIT FOR 5 NS; I_TB<="0100"; S_TB<="01"; WAIT FOR 5 NS; I_TB<="0010"; S_TB<="10"; WAIT FOR 5 NS; END PROCESS; end Behavioral;
08-21-2018 11:56 PM
The instantation of the mux is incorrect in the testbench, you could figure that out from the indicated logfile:
ERROR: [VRFC 10-37] mux4_1 has only 3 ports [xxxx/project_4/project_4.srcs/sources_1/new/muxtb.vhd:21]
The correct way would be:
--M1:MUX4_1 PORT MAP(I_TB(0),I_TB(1),I_TB(2),I_TB(3),S_TB(0),S_TB(1),Y_TB);
M1:MUX4_1 PORT MAP(I_TB,S_TB,Y_TB);
Also there are much nicer ways of writing multiplexers, one way would be (and there are many shorter ways to write this, for example using when, for loops etc.). I did not simulate this but looks correct ;)
architecture arch of MUX4_1 is
begin
process (I, S)
begin
case S is
when "00" => Y <= I(0);
when "01" => Y <= I(1);
when "10" => Y <= I(2);
when "11" => Y <= I(3);
when others => Y <= I(0);
end case;
end process;
end arch;
--Kim
