sorgius01
ERROR: launching PlanAhead failed:
I want to start  PlanAhead from ISE11.3.
(New Design, first P&R is done)
I get allways this message:
Started : "I/O Pin Planning (PlanAhead) - Pre-Synthesis".                       (Or  Started : "I/O Pin Planning (PlanAhead) -Post-Synthesis". or Started : "Floorplan Area/IO/Logic (PlanAhead)".)
Preparing PlanAhead launch script...
ERROR: launching PlanAhead failed: extra characters after close-quote.
I don't find a solution to start PlanAhead.
Does anybody known this problem???
heso
pkortekaas
I have the same problem. Is there a solution already?
Peter
daughtry
Looks like there is an error or corruption in the tcl script that Project Navigator is passing to PlanAhead when it is launched.  Please contact technical support to help resolve this:
www.xilinx.com/support
You can also try creating a standalone planAhead project (rather than calling it from Project Navigator through the builti-in processes).  If you invoke PlanAhead for the first time, there is a getting started page with links to tutorials on using PlanAhead with Project Navigator as well as using it standalone.  Look for the Quick Overview.
Greg Daughtry
Vivado Product Marketing Director, Xilinx, Inc.
sorgius01
The same error appears with a new installation of the ISE 11.3 on a new PC!
Starting PlanAhead with a standalone project seems to work but it is not easy to start this way!
krishnan
Do you have spaces in your project directory path?
sorgius01
No!
I know such problems with spaces.
I use underscores instead.
