colombini_luca
Error while running a script for UG947 (partial reconfiguration tutorial)
I am getting an error while running the run_pr.tcl script used un UG947 (partial reconfiguration tutorial).
The error is:
## foreach config [sort_configurations [get_implementations "impl pr.impl" &&]] {
## #Override directives if directive file is specified
## if {[info exists useDirectives]} {
## puts "#HD: Overriding directives for configuration $config"
## set_directives impl $config
## implement $config
error deleting "D:/work/led_shift_count_us/Implement/Config_shift_right_count_up_implement\command.log": permission denied
ERROR: file command failed.
file delete -force ./Implement/Config_shift_right_count_up_implement
while executing
"error $errMsg"
invoked from within
"if { [catch $command errMsg] && !$quiet} {
append errMsg "\nERROR: $commandName command failed.\n\t$command\n"
error $errMsg
invoked from within
"if {[llength $log] > 0} {
if { [catch "$command > $log" errMsg] && !$quiet } {
puts "#HD: Command \'$commandName\' failed! Parsing $log..."
(procedure "command" line 41)
invoked from within
"command "file delete -force $resultDir""
(procedure "implement" line 63)
invoked from within
"implement $config"
("foreach" body line 7)
invoked from within
"foreach config [sort_configurations [get_implementations "impl pr.impl" &&]] {
if {[info ex..."
(file "./Tcl_HD/run.tcl" line 12)
while executing
"source $tclDir/run.tcl"
(file "run_pr.tcl" line 72)
Has anyone got the same error?
Luca
