k_kowalski
Export Design to Spreadsheet
Is there a way to export a vivado (2018.2) project design layout to a .csv file? I want to document all modules, inputs/outputs, and pin layout.
timothyv
Hello @k_kowalski
I have attached a link to a past forum question that is relevant to your question. I have also attached a link to an answer record regarding exporting a design to .csv file.
I hope this helps!
Forum: https://forums.xilinx.com/t5/Design-Methodologies-and/Exporting-IO-report-in-Vivado-to-CSV-which-includes-explicit/td-p/389657
Answer Record: https://www.xilinx.com/support/answers/64807.html
timothyv
Hello @k_kowalski
I hope this helps!
