Visitor kumakumo
How to high impedance setting for unused pins in vivado
  I want to connect vcc or gnd for unused pin. and my bread board is so small. so i have to make a forced connection. how to this?
Re: How to high impedance setting for unused pins in vivado
To set all unused pins to a high-impedance state in TCL use this command: "set_property BITSTREAM.CONFIG.UNUSEDPIN PULLUP [get_designs netlist_1]"
In GUI:  "Generate Programming File" in process tab -> properties -> configuration option -> Set Unused IOB Pins"
Above is from: https://forums.xilinx.com/t5/Vivado-TCL-Community/How-to-use-tcl-to-set-all-unused-pin-to-high-impedance-state/td-p/738417
Also here is an AR discussing how to set an output to high impedance: https://www.xilinx.com/support/answers/3030.html
I hope that helps!
Ebrahim
Scholar drjohnsmith
why do you want to connect unused pins to Vcc or gnd. The built in pull ups hold un used inputs in a stable place, its not like you old chips .
