hs.sls
How to migrate Vivado 2018.3 to ISE 14.7
I have one design for vivado 2018.3 and i want to check that design on spartan 6 family.
But spartan 6 family is not supported in vivado.
So, one option is migrate design from vivado 2018.3 to ISE 14.7.
Please guide me with proper solution.
Thank You
aswinjohn
As per AR#53109 , the Vivado tool supports only 7-series and above devices.
If you are planning to migrate the design from Vivado to ISE, the following user guide provides details on the areas which require updates as part of the migration process.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug911-vivado-migration.pdf
NOTE: Though the document is meant for ISE to Vivado migration, it still provides necessary information on the design changes to be performed in the ISE to Vivado migration
drjohnsmith
Your going to have to provide a lot more detail,
first up what coding language are you using ,
General pointers,
if the code is all RTL, for instance VHDL, then relativly easy,
if in things like SystemVerilog of HLS, then much more re writting is going to be needed.
Once you have the coding language sorted, and your an expert in that language,
then the things to look out for are IP, and chip specific bits,
i.e. Spartan has different clock arrangements than 7 series.
The instantiated blocks from 7 series is unlikely to work in Spartan 6,
i.e if you have any memory blocks instantiated , then these are going to have to be re generated,
Any IP you have, you are going to have to check its spartan 6 compatible, Things like DDR or PCIe are unlikely to be,
One tip, having done a good few conversions like this,
   Spend a good time making certain you have as good a self testing test bench of the old code before you chnage any of the code for the spartan 6,
    You you will run the test bench multi times to check your design is compatable,
hs.sls
Thank you @aswinjohn
Is there any way to migrate custom IP core from vivado 2018.3 to ISE 14.7 ?
