How to use a general I/O pin as a dedicated clock pin.
Hi, everyone...
Accidentally, I assign a general I/O pin of SPARTAN-3 as system clk.
And I code as following, bit I have an error message.
Of cause, the error message is that A clock IOB / clock component is not placed at an optimal clock IOB.
As far as I know, I can remove this error message using component ibuf and bufg as following.
I don't understand why the error message is occurred...
entity test_clk is
    port
       clk_in : in std_logic;
       data : out std_logic
end test_clk;
architecture Behavioral of test_clk is
    signal clk0 : std_logic;
    component ibuf
    port
         i : in std_logic;
        o : out std_logic
    end component;
    component bufg
    port
        i : in std_logic;
       o : out std_logic
    end component;
begin
   U0 : ibuf
   port map
      i=>clk_in,
      o=>clk0
   U1 : bufg
   port map
      i=>clk0,
     o=>clk
Read the Global Clock Network in the Datasheet.
Spartan-3 devices have Global Clock inputs called GCLK0 - GCLKn. These inputs provide access to a low-capacitance, low-skew network that is well-suited to
carrying high-frequency signals.
Also read the IOB part in the Datasheet. Where as in IOB, there are three main signal paths within the IOB: the output path, input path, and 3-state path. Each path has its own pair of storage elements that can act as either registers or latches.
When in your code you are using a signal inside a process with " ' Event ", it consider it as a clock. In a digital circuit if your Clk is unstable (because of propogation delays, path delays etc....) then your circuit is more prone to eronious behaviour. So it is always advisible not only to use Global Clock pins for Clk inputs but also to make sure that your clock signal is routed through the Global Clock Network..
Shantanu
Shantanu Sarkar
http://www.linkedin.com/pub/shantanu-sarkar/0/33a/335
Are you getting an error message or a warning?  It is legal to use a general purpose IO pin
to bring in a global clock but it is very sub-optimal.
Since the GP-IO pin does not have a dedicated path to a clock buffer, it has to use general
fabric routing which can cause excessive delay and possibly duty cycle distortion.  You may
not care about either of these, but if you're trying to synchronously get data from an external
source, you may have some difficulties with setup/hold time.
You can add MAXDELAY type constraints in your ucf file to try to force an acceptable delay
on the clock signal, but the FPGA can only do so much since it has to use fabric to route the
pad to the global clock.
John Providenza
