Voyager
Voyager
How to version control?
How to keep track of versions and changes with a project involving BDs, VHDL/ Verilog files, packaged IPs and software?
We have tried creating tcl files (the so-called non project mode, I think) but run into problems... (can't specify as it wasn't me)
Is there any guidance on how to keep VC of such type of projects?
Re: How to version control?
Hi @johnvivm,
Have a look into this UG , Chapter 5 for Source Management and Revision Control Recommendations
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug892-vivado-design-flows-overview.pdf#nameddest=xUsingSourceControlSystemsWithTheVivadoTool
It may help you out in revision control issue.
hemangd
Hi @johnvivm,
hemangd
HI @johnvivm,
Let me know if you have further queries on this thread, or you can close this thread by marking it accepted solution.
hemangd
