@ida
ICAP for PR FPGA programming
I am currently working on a design where only one cell content ever changes. I would like to program the FPGA with the static part and only generate a new bitstream for this one particular cell (the interface netlist for this cell is also fixed) and then program the FPGA through ICAP (from UltraScale processor). I have seen some PR tutorials but in every design both the static and the variable bitstream were generated at the same time, but I want to generate the static bitstream only once. Is this even possible with ICAP and if yes, is there some tutorial about this?
Thanks!
hongh
The partial bitstream can be generated without full design bitstream with the option -cell in write_bitstream command:
Ex: write_bitstream -cell [get_cells rm_cell_name] XX.bit
