IP Interface Definition process
To reduce a number of connections in BD I want to create new interfaces (ARM_BUS and EXP_BUS) from the list of the existing ports. I have attached a snapshot, showing a list of ports in IP. Could you please explain the steps.
Thank you.
Re: IP Interface Definition process
@arotenst
Check Chapter 5 in below user guide which has the required information:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1118-vivado-creating-packaging-custom-ip.pdf#page=82
--Syed
Syed,
I asked for the steps. I have this document and read it. Vivado does weird things.  It creates an interface with a port’s name my mouse pointed to, not with the name I define. How to add more ports to this interface?
