Integrate generated IP inside Partition Definition
Hope some of the experts can help me to solve the issue.
I have a design, which will be embedded inside Partition Definition for Partial Reconfiguration.
I have generated a FIFO through IP Catalog to integrate inside my design.
Unfortunately when my design is set as a Partition Definition the integrated module (instantiation of the Generated FIFO) is somehow pushed out of Partition Definition and my design synthesized as Out_Of_Context fails claiming the FIFO module is not found.
If my design is not set as a Partition Definition then synthesis passes without any issue.
Can an expert please explain how to overcome this problem?
I am working on Vivado 2017.4 version.
Could this be tool limitation?
Arsen.
Problem is solved.
Had to just click right button on the FIFO IP inside Sources window and say "move to Reconfigurable Module".
Confusing... But issue is solve!
Problem is solved.
