Observer janet
Is there a way that I can generated different bit files by using different area constaints?
Hi All,
I am encounterring a route congestion problem.
I want to explore with different area constraints.
Is there a way that I can have different area constraints for different buildings at the same time.
So after the bit gen, I can have different bit files for each building all in once.
Thanks~!
Voyager
Voyager
Re: Is there a way that I can generated different bit files by using different area constaints?
Check out UG892, Chapter 3, "Configuring Synthesis and Implementation Runs":
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug892-vivado-design-flows-overview.pdf
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
You can create different constraint files for the different constraints, create separate runs that use them, and the review those runs independently.
e.g.
Constraint_file_1 -> Impl_1
Constraint_file_2 -> Impl_2
etc...
