[NgdBuild 1446] The BUFG clock buffer 'instance0/instanceCOMPRECONF/instance2/clk7_BUFG' is not allowed
hello,
i am working on planahead 14.7.
while i applying partial reconfiguration to my design i got the error listed below.
[NgdBuild 1446] The BUFG clock buffer 'instance0/instanceCOMPRECONF/instance2/clk7_BUFG' is not allowed within the Reconfigurable Partition '/vbsme_complet/instance0/instanceCOMPRECONF'. Please do one of the following to resolve the error: 1. Move the BUFG to a static (non-reconfigurable) module 2. Change the buffer type from BUFG to BUFR 3. Remove the Reconfigurable Partition
could you help me please I'm a beginer in planahead
Hi @saif123,
Can you please check the  page106 of the below linked document, which states that clocks and clock modifying logic has to placed in Static logic .
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug702.pdf
i.e., can you please move the instantiation of BUFG to the non reconfigurable (static) module.
Thanks & Regards,
A.Shameer.
