Open IP-XACT File defaults custom IPs
When I try just to review my custom IPs: File -> IP -> Open IP-XACT File…-> component.xml, my IPs turn into the default state: all names, descriptions and added .xci files, interfaces are gone. Can it be a bug? I use Vivado 2018.3.
Thank you.
Re: Open IP-XACT File defaults custom IPs
@arotenst
Can you try these steps:
1. From IP catalog, right click on your custom IP and select Edit in IP packager.
2. This will open temp Vivado project. Check if the design files in this temp project have your changes/modification.
--Syed
Edit in IP packager works normal. No changes in IPs. Then I tried "Open IP-XACT File" again. No problem. Do you know the explanation what happened?
Just one thing is not expected. I got a message for one IP (attached). Not clear why.
Thank you,
Alex
