Observer los_galacticos
PID DC motor control
Hi everyone. I want to design pid implementation for dual dc motor control. I am using the Spartan 3- starter kit board. I have ultrasonic range sensor and i can show the object's range on seven segment display as centimeter. And also, i can control dual dc motor by using pwm technique on fpga board. But, i can not put everything together.
I can get distance value as centimeter and i can control dc motor by using pwm technique but how can i put pid on it? or how should i write pid code? Could you please help me to get rid of this chronic issue?
Thaks.
Scholar u4223374
Re: PID DC motor control
What is the controlled variable? Distance to target? Velocity?
Distance to target is potentially a tricky one as it requires the ability to reverse the motor - and most motors/controllers aren't going to give a linear response around that region.
Scholar jmcclusk
This is a duplicate post, and I already replied with a solution here:
https://forums.xilinx.com/t5/Spartan-Family-FPGAs/PID-control-implementation-for-DC-motor-control/m-p/860169/highlight/true#M37031
i want to control dc motor's speed. But i have range sensor not speed sensor. That's why i tried to change distance value to mean value speed by using trigger time of range sensor. Than, i send the information as speed into pid block. Actually i did this but when we look at the whole part of this design, is the system has PID  control ? if it is ok , where the pid control is? This is my main problem.
Hi @los_galacticos, have referred to @jmcclusk's reply on your duplicate post? Please do not post the same query on multiple boards.
