PR: Issue with black box
I am following lab3 from https://www.xilinx.com/support/university/vivado/vivado-workshops/Vivado-partial-reconfiguration-flow-zynq.html to have 2 AxiLite reconfigurable modules via PCAP. I am trying to adapt the shipped example to my own design. They are two counters within a custom AxiLite IP. For the black box, I followed the example from UG901, Black Box section in VHDL. This is my design:
In AxiLitePR_Counter_v1_0_S00_AXI I instantiate the black box:
    inst_AxiLitePR: entity work.Counter PORT MAP(
        Clk => S_AXI_ACLK,
        Reset => S_AXI_ARESETN,
        Control => slv_reg1,
        Count => Result
And "Counter" looks like this (foollowing UG901)
-- https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug901-vivado-synthesis.pdf (Page 160 - Black Box (VHDL) section.)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity Counter is
    Port ( Clk : in STD_LOGIC;
           Reset: in STD_LOGIC;
           Control : in STD_LOGIC_VECTOR(31 downto 0);
           Count : out STD_LOGIC_VECTOR(31 downto 0));
end Counter;
architecture rtl of Counter is
    component Counter_black_box
   end component;
   attribute black_box : string;
   attribute black_box of Counter_black_box : component is "yes";
begin
    U1: Counter_black_box port map (Clk=>Clk, Reset=>Reset, Control=>Control, Count=>Count);
end rtl;
I synthesize this and after I open the static design's checkpoint I cannot see the instantiated design:
Therefore, there isn't a black box cell to continue with the partial reconfiguration flow.
I also tried to have the black box with just the entity:
library IEEE;
entity Counter is
end Counter;
begin
end rtl;
But the result was the same.
Are those VHDL blocks correct? Is there any property that I should set before packaging the AxiIP?
Thanks for the help.
Re: PR: Issue with black box
Hi @hongh,
Only having the entity like in my previous post it worked. I managed to reconfigure that black box.
Hi, @aripod ,
Before you suspect the issue occurs during packaging the Axi_IP, you should synthesize the IP alone first and observe whether the black_box exists in the design already.
@hongh,
I synthesized the IP before packaging it and there is no black box there. So far I tried with the following 3 cases:
library IEEE;
entity Counter is
end Counter;
begin
end rtl;
library IEEE;
entity Counter is
end Counter;
    component CounterEmpty
       end component;
   attribute black_box of CounterEmpty : component is "yes";
begin
end rtl;
-- This is exactly how it is shown on UG909 (black box in VHDL)
library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity Counter is Port ( Clk : in STD_LOGIC; Reset: in STD_LOGIC; Control : in STD_LOGIC_VECTOR(31 downto 0); Count : out STD_LOGIC_VECTOR(31 downto 0)); end Counter; architecture rtl of Counter is component CounterEmpty Port ( Clk : in STD_LOGIC; Reset: in STD_LOGIC; Control : in STD_LOGIC_VECTOR(31 downto 0); Count : out STD_LOGIC_VECTOR(31 downto 0)); end component; attribute black_box : string; attribute black_box of CounterEmpty : component is "yes"; begin U1: CounterEmpty port map(Clk => Clk, Reset => Reset, Control => Control, Count => Count); end rtl;
All 3 cases don't show a blackbox:
And as you can see, it is being instantiated properly:
How should I define it then?
I now synthesized the black box like this:
library IEEE;
entity Counter is
end Counter;
And in the source's hierarchy:
Regardless, when I open the synthesized design, I get a critical warning (expected, I would say):
 [Project 1-486] Could not resolve non-primitive black box cell 'Counter' instantiated as 'AxiLitePR_Counter_v1_0_S00_AXI_inst/inst_counter' [/home/ariel/Documents/AxiLite/Vivado/AxiLitePR/ip_repo/AxiLitePR_Counter_1.0/hdl/AxiLitePR_Counter_v1_0_S00_AXI.vhd:388]
And the black box is there:
Hi, @aripod ,
In your design, Counter is a blackbox, but actually you are trying to create a black box "CounterEmpty" or "Counter_black_box ".
You can try to add the below content in AxiLitePR_Counter_v1_0_S00_AXI.vhd:
attribute black_box of Counter : component is "yes";
Hi @hongh,
Hi, @aripod ,
Thank you for sharing the good news.
Please don't forget to close the thread.
