brent.aandd
Partial reconfiguration EXCEPTION_ACCESS_VIOLATION during writing of static routed design
I am updating my partial reconfiguration design from 2017.2 to 2019.2. I have run into a particularly tricky problem where I get a EXCEPTION_ACCESS_VIOLATION and my terminal crashes. This happens after I have locked the routing and as I am trying to write out the static routed dcp file.
I have noticed that this seems to work (most of the time) if I run start_gui, however, I have seen this fail also.
Anyone have any experience with this?
Thanks!
marcb
Hi @brent.aandd
This would appear to be related to a newly reported issue below. Is the OS in this case windows? Does the below patch help?
https://www.xilinx.com/support/answers/75507.html
marcb
Hi @brent.aandd
brent.aandd
Yes, it is. I reported This fix worked for me.
