Visitor jeremiev
Partial reconfiguration decoupler
I generated a PR decoupler and I noticed it always gives me a AXI WSTRB witdth of 1 instead of 4.
It means word accesses turn into byte accesses.
It's fairly new to me so maybe I missed something.
I've checked on vivado 2019.1.1.
The IP always has
s_intf_0_WSTRB : IN STD_LOGIC_VECTOR(0 DOWNTO 0);
rp_intf_0_WSTRB : OUT STD_LOGIC_VECTOR(0 DOWNTO 0);
Jeremie
Re: Partial reconfiguration decoupler
Hi, @jeremiev ,
You can try to modify the width of "s_intf_0_WSTRB"/ "rp_intf_0_WSTRB" directly in "Interface Option" as the below pic
Hi, @jeremiev ,
Could you provide the XCI of your PR decoupler IP?
Visitor jeremiev
When I generate it I get the AXI WSTRB as a one bit vector whereas I believe it should be 4 bits.
In the vho I have
I didn't find a way to force it to be 4 bits.
I've tried to post the xci and even txt file but it wouldn't let me so I copied it below. It said the content doesn't match the file extension
<?xml version="1.0" encoding="UTF-8"?>
<spirit:design xmlns:xilinx="http://www.xilinx.com" xmlns:spirit="http://www.spiritconsortium.org/XMLSchema/SPIRIT/1685-2009" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<spirit:vendor>xilinx.com</spirit:vendor>
<spirit:library>xci</spirit:library>
<spirit:name>unknown</spirit:name>
<spirit:version>1.0</spirit:version>
<spirit:componentInstances>
<spirit:componentInstance>
<spirit:instanceName>pr_decoupler_0</spirit:instanceName>
<spirit:componentRef spirit:vendor="xilinx.com" spirit:library="ip" spirit:name="pr_decoupler" spirit:version="1.0"/>
<spirit:configurableElementValues>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.DECOUPLE_REF_CLK_CLOCK.ASSOCIATED_BUSIF"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.DECOUPLE_REF_CLK_CLOCK.ASSOCIATED_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.DECOUPLE_REF_CLK_CLOCK.CLK_DOMAIN"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.DECOUPLE_REF_CLK_CLOCK.FREQ_HZ">100000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.DECOUPLE_REF_CLK_CLOCK.INSERT_VIP">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.DECOUPLE_REF_CLK_CLOCK.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.INTF_0_REF_CLK_CLOCK.ASSOCIATED_BUSIF">s_intf_0:rp_intf_0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.INTF_0_REF_CLK_CLOCK.ASSOCIATED_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.INTF_0_REF_CLK_CLOCK.CLK_DOMAIN"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.INTF_0_REF_CLK_CLOCK.FREQ_HZ">100000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.INTF_0_REF_CLK_CLOCK.INSERT_VIP">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.INTF_0_REF_CLK_CLOCK.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.ADDR_WIDTH">32</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.ARUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.AWUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.BUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.CLK_DOMAIN"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.DATA_WIDTH">32</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.FREQ_HZ">100000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_BRESP">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_BURST">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_CACHE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_LOCK">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_PROT">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_QOS">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_REGION">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_RRESP">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_WSTRB">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.ID_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.INSERT_VIP">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.MAX_BURST_LENGTH">256</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.MISC.CLK_REQUIRED">FALSE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.NUM_READ_OUTSTANDING">2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.NUM_READ_THREADS">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.NUM_WRITE_OUTSTANDING">2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.NUM_WRITE_THREADS">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.PROTOCOL">AXI4</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.READ_WRITE_MODE">READ_WRITE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.RUSER_BITS_PER_BYTE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.RUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.SUPPORTS_NARROW_BURST">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.WUSER_BITS_PER_BYTE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.WUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.ADDR_WIDTH">32</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.ARUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.AWUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.BUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.CLK_DOMAIN"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.DATA_WIDTH">32</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.FREQ_HZ">100000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_BRESP">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_BURST">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_CACHE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_LOCK">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_PROT">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_QOS">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_REGION">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_RRESP">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_WSTRB">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.ID_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.INSERT_VIP">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.MAX_BURST_LENGTH">256</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.MISC.CLK_REQUIRED">FALSE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.NUM_READ_OUTSTANDING">2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.NUM_READ_THREADS">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.NUM_WRITE_OUTSTANDING">2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.NUM_WRITE_THREADS">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.PROTOCOL">AXI4</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.READ_WRITE_MODE">READ_WRITE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.RUSER_BITS_PER_BYTE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.RUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.SUPPORTS_NARROW_BURST">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.WUSER_BITS_PER_BYTE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_INTF_0.WUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="MODELPARAM_VALUE.C_XDEVICEFAMILY">kintexu</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.ALL_PARAMS">INTF {intf_0 {ID 0 VLNV xilinx.com:interface:aximm_rtl:1.0 MODE slave CDC_STAGES 3}} HAS_AXI_LITE 0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Component_Name">pr_decoupler_0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_HAS_AXIS_CONTROL">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_HAS_AXIS_STATUS">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_HAS_AXI_LITE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_HAS_SIGNAL_CONTROL">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_HAS_SIGNAL_STATUS">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_INTERFACE_NAME">intf_0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_INTERFACE_PROTOCOL">axi4</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_NEW_SIGNAL_NAME"> </spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SELECT_CDC_STAGES">3</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SELECT_INTERFACE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SELECT_MODE">slave</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SELECT_VLNV">xilinx.com:interface:aximm_rtl:1.0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_0">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_1">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_2">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_3">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_4">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_5">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_6">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_7">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_8">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_9">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_0">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_1">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_2">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_3">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_4">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_5">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_6">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_7">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_8">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_VALUE_9">0x0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_0">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_1">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_2">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_3">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_4">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_5">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_6">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_7">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_8">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DELETE_9">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_0">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_1">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_2">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_3">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_4">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_5">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_6">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_7">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_8">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_DIRECTION_9">s</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_0">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_1">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_2">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_3">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_4">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_5">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_6">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_7">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_8">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_MANAGEMENT_9">auto</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_0">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_1">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_2">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_3">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_4">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_5">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_6">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_7">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_8">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_9">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_0">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_1">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_2">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_3">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_4">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_5">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_6">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_7">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_8">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_RESOURCE_9">infer</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_0">ARVALID</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_1">ARREADY</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_2">AWVALID</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_3">AWREADY</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_4">BVALID</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_5">BREADY</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_6">RVALID</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_7">RREADY</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_8">WVALID</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_9">WREADY</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_0">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_1">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_2">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_3">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_4">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_5">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_6">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_7">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_8">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GUI_SIGNAL_WIDTH_9">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.IPI_ALL_PARAMS"> </spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.ARCHITECTURE">kintexu</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.BASE_BOARD_PART">xilinx.com:kcu105:part0:1.6</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.BOARD_CONNECTIONS"/>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.DEVICE">xcku040</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.PACKAGE">ffva1156</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.PREFHDL">VHDL</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.SILICON_REVISION"/>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.SIMULATOR_LANGUAGE">MIXED</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.SPEEDGRADE">-2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.STATIC_POWER"/>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.TEMPERATURE_GRADE">E</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.USE_RDI_CUSTOMIZATION">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.USE_RDI_GENERATION">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.IPCONTEXT">IP_Flow</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.IPREVISION">7</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.MANAGED">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.OUTPUTDIR">.</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SELECTEDSIMMODEL"/>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SHAREDDIR">.</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SWVERSION">2019.1.1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SYNTHESISFLOW">OUT_OF_CONTEXT</spirit:configurableElementValue>
</spirit:configurableElementValues>
<spirit:vendorExtensions>
<xilinx:componentInstanceExtensions>
<xilinx:configElementInfos>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.ARUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.AWUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.BUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_CACHE" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_LOCK" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_PROT" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_QOS" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.HAS_REGION" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.ID_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.RUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RP_INTF_0.WUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.ARUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.AWUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.BUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_CACHE" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_LOCK" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_PROT" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_QOS" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.HAS_REGION" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.ID_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.RUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_INTF_0.WUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.ALL_PARAMS" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_HAS_AXI_LITE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_INTERFACE_NAME" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_INTERFACE_PROTOCOL" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SELECT_CDC_STAGES" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SELECT_INTERFACE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SELECT_MODE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SELECT_VLNV" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_0" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_1" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_2" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_3" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_4" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_5" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_6" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_7" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_8" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_DECOUPLED_9" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_0" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_1" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_2" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_3" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_4" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_5" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_6" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_7" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_8" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_PRESENT_9" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_0" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_1" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_2" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_3" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_4" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_5" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_6" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_7" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_8" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.GUI_SIGNAL_SELECT_9" xilinx:valueSource="user"/>
</xilinx:configElementInfos>
</xilinx:componentInstanceExtensions>
</spirit:vendorExtensions>
</spirit:componentInstance>
</spirit:componentInstances>
</spirit:design>
Hi, @jeremiev ,
Visitor jeremiev
Nice, that's what I was after and I would have set it if it was showing like that for me.
My question should have been: My interface option is not showing the strobe so I'm not able to make it a 4 bit bus. How can I configure it to show the AXI bus signals?
Your view explained it to me, it's not showing all the signals in the interface option but you can actually pick which signal you want it to show and set their width.
Thanks for your help. I'm good now. Just as a comment that width should be 4 by default.
Jeremie
Hi, @jeremiev ,
Thanks for your reasonable suggestion and it has been reflected to the developer.
Hi, @jeremiev ,
In 2019.2, the default width of WSTRB has been changed to 4 ([3:0]) to be consistent with WDATA.
