Partial reconfiguration using VIVADO and zedboard
I am trying to implement an algorithm on zedboard using vivado 2018.3. Initially i just configured my FPGA and after verifying the results, i moved towards the partial reconfiguration. In my standard design, i used block designs. In partial reconfiguration project, i tried to declare a part of my code as PR, but when i use a block design (for AXI and IP packaging), it gives me errors.
Secondly, i wanted to ask can i use netlist directly and declare it as PR module?
Any answer would really be appreciated.
_HF
Re: Partial reconfiguration using VIVADO and zedboard
Hi, hunainafarid02@gmail.com ,
IP Integrator support is not in place. Block Diagrams cannot be included as RMs or
within RMs. Modules within Block Diagrams cannot be set as RMs.
Source types for Reconfigurable Modules: RTL, DCP, EDIF, XDC, XCI, XCIX.
 XCI or XCIX (Xilinx IP) cannot be the top level.
 EDIF cannot be a sub-module
I figured out a way to do the partial reconfiguration. yes you were right, i could not do it with Block diagrams. I used the non project mode, and were able to generate the bit streams. Now i am facing another issue. I am getting garbage values on my terminal. for example, i have declared a one bit value in my program, and i should get either 1 or 0 on the terminal but instead i get 9DF39DF3. Also for data out i am getting 128 bits but not correct value.
if i remove the partial reconfiguration from the same project, i get the correct values. but when i declare the project as partially reconfigurable, i get wrong values. Can you guide me where i am doing wrong?
P.S i am using AXI4 LITE interface. and SDK terminal for results.
Waiting for response please.
