Please verify the instance name in the .bmm file and the netlist. The BRAM initialization strings will not get populated with data
I mapped each Reconfigurable Module(RM) to appropriate pblocks and ran the top level implementation.
I saved this design as config_routed.dcp.
Then, I opened config_routed.dcp to black box out RMs to generate static design checkpoint.
I've got the warning below.
CRITICAL WARNING: [Memdata 28-204] The BRAM instance design_1_i/leaf_empty_0/inst/leaf_v0_2_i/microblaze_0_local_memory/lmb_bram/U0/inst_blk_mem_gen/gnbram.gnative_mem_map_bmg.native_mem_map_blk_mem_gen/valid.cstr/ramloop[0].ram.r/prim_noinit.ram/DEVICE_8SERIES.WITH_BMM_INFO.TRUE_DP.SIMPLE_PRIM36.SERIES8_TDP_SP36_NO_ECC_ATTR.ram could not be found in the netlist. Please verify the instance name in the .bmm file and the netlist. The BRAM initialization strings will not get populated with data.
The RM contains BRAM, and because I black box it out, of course, the BRAM initialization strings will not get populated with data, right? I'm just asking because it raises critical warning.
Thanks in advance.
Re: Please verify the instance name in the .bmm file and the netlist. The BRAM initialization strings will not get populated with data
Hello @moon5756,
You are correct.  When you black-box modules you are removing the underlying instances so the constraint is pointing to a cell that doesn’t exist.  This is expected.
Chris
i also meet this issue
Hello @moon5756,
Chris
