Problem in tutorial of partial reconfigration project flow
I have tried partial reconfiguration (PR) tutorial using UG947 (2017.4).
(1)
I have created project and added sources (.v and .xdc).
But, I can't make the hierarchy correct.
PR target modules (inst_shift, inst_count) are loaded from top.v.
These modules is black box in top.v and I can't create partition definition to them.
Would you tell me how to loaded from shift_right.v and count_up.v ?
(2)
fig.21 in UG947 (2017.4) shows PR target modules are shift_low and shift_high.
Is it old version?
Best Regards,
Tetsuo
I'm wrong.
There are separated sources for project flow and sources for tcl flow.
PR target module is comment on top.v for project flow.
I'm sorry, @hongh @lowearthorbit
Were you using Vivado release 2017.4?
Hi, @tetsuo_yamashita ,
Which top.v file are you using?
Could you show us where top.v is stored and the content of top.v?
Do you keep the below content in the end of top.v in comments?
// black box definition for module_shift
//module shift(
// input en,
// input clk,
// input [11:0] addr,
// output [3:0] data_out);
//endmodule
Thank you for your replies!
@lowearthorbit
I'm using Vivado 2017.4.
Vivado v2017.4 (64-bit)
SW Build: 2086221 on Fri Dec 15 20:54:30 MST 2017
IP Build: 2085800 on Fri Dec 15 22:25:07 MST 2017
@hongh
The path of top.v is ./ug947-vivado-partial-reconfiguration-tutorial/led_shift_count_us/Sources/hdl/top/top.v .
I'm using the top.v without editing.
Because, a procedure of editing top.v is not on the tutorial document.
module top(
   input        clk_p,       // 200MHz differential input clock
   input        clk_n,       // 200MHz differential input clock
   input        rst_n,       // Reset mapped to center push button
   output [3:0] count_out,   // mapped to general purpose LEDs[4-7]
   output [3:0] shift_out    // mapped to general purpose LEDs[0-3]
endmodule
module shift(
   input         en,
   input         clk,
   input  [11:0] addr,
endmodule
// black box definition for module_count
module count(
   input        rst,
   input        clk,
   output [3:0] count_out);
endmodule
I'm wrong.
