Program Counter
I am attempting to write a program counter in VHDL for my processor project. The register is 64 bits and is incremented by 1 instead of 4. Same goes for when branching. I am getting an error of "0 definitions of operator +" on line 51. I am not really sure how to fix it, it seems to be the only error I am encountering. Any help with the PC or fixing this error is appreciated, thank you.
entity programCounter is
    port ( CLK : in STD_LOGIC;
           SEL : in STD_LOGIC;
           signExtend : in STD_LOGIC_VECTOR(63 downto 0);
           Q : out STD_LOGIC_VECTOR(63 downto 0));
end programCounter;
architecture Behavioral of programCounter is
signal current : STD_LOGIC_VECTOR(63 downto 0) := X"0000000000000000";
begin
process(CLK)
begin
    if RISING_EDGE(CLK) then
        if SEL = '0' then
            current <= STD_LOGIC_VECTOR(unsigned(current) + 1);
        elsif SEL = '1' then
            current <= STD_LOGIC_VECTOR(unsigned(current) + signed(signExtend));
        end if;
    end if;
end process;
    Q <= current;
end Behavioral;
Scholar jmcclusk
Re: Program Counter
you can't mix signed and unsigned together with a "+" between them.  Addition/subtraction only works between identical types.
           SEL : in STD_LOGIC;
end programCounter;
begin
process(CLK)
begin
        if SEL = '0' then
            current <= STD_LOGIC_VECTOR(signed(current) + signed(signExtend));
        end if;
    end if;
end process;
    Q <= current;
end Behaviora
Scholar jmcclusk
Re: Program Counter
           SEL : in STD_LOGIC;
end programCounter;
begin
process(CLK)
begin
        if SEL = '0' then
        end if;
    end if;
end process;
    Q <= current;
end Behaviora
Re: Program Counter
Makes sense, can't believe I didn't realize that. Thanks
Scholar jmcclusk
Re: Program Counter
Now close the thread by marking the post "Accept as solution".    Keep asking questions!
